Hi everyone....
I would like to share a tube mic preamp I design. I have not seen a mic preamp that can switch between SE/PP and TRI-UL-PEN. It sounds nice och has a lot of diffrent flavours. It has no NFB. The idea was also to design the preamp around cheap but good performing tubes. The russian/soviet 6J32P, 6N1P and 6N6P fit that bill.
I used the UTM-3580 PP or Carnhill WTB2291 (even if it not design as a PP transfomer it does a nice job), I guess you could use a PP transfomer from edcore if you live in US. As input transfomer anything from 1:4 to 1:10 should work fine depending on taste... headroom, s/n etc...
My build also has DI, HP, input and output PAD, phase reverse and 48V... The B+ is around 250VdC....
Picture in Post 16 shows how implement a DI that breaks the MIC connection, and how to integrate a -20dB PAD and Phantom power and polarity reverse.
At the output there can be a output PAD and a load resistor that forces the line stage to work hard and produce harmonic distortion.
I omitted the gain control switch in the input stage, because it interacts with the tri/pen controll and because the triode mode makes the input stage clean enough, more feedback makes the sound sterile in my opinion. This is a coloured pre amp...
Fre. response -3dB ca. 20Hz-30KHz.
Clean setting: TRI + PP= THD+N: 0,18% at 1KHz 0 dBu (without NFB).
Coloured setting: PEN + SE + -15dB OUTPUT PAD: THD+N: 2,7 % (without NFB).
The H2 and H3 content varies depending on mode. PP cancels H2, PEN increases H3.
The TRI/PEN and PP/SE modes can alter the preamps gain by about 20 dB.
The 1K5 dropping resistor in the PSU high voltage rail needs to be in the 7-10 W range otherwise there will be smoke...
Audio sample post #24: 4in1 tube mic preamp SE/PP TRI/PEN
