Kid Squid
Hell, I've been away far too long !!!
Truly amazing....
Regards,
Steve
Truly amazing....
Regards,
Steve
I hope I am not blatantly hi-jacking here..... Nielsk..... You like the Edcor 10k/10k for balanced line-level input? I think I have a couple of those in my shop but I haven't actually used them recently. I am a fan of transformer input for line-level. It's always a hard choice between Tx-balanced and electronically-balanced. DW.nielsk said:I suggest an option (possible strap jumper and pads...) for transformer input, it could be mounted off module (as many were in older API consoles). I have been very happy with the sound of the Edcor 10K/10K in this application, I like it better than differential in to a 2520, and the price is right.
I had given this some serious thought last year when I got involved with Volker and Cemal for the 51x project. There is definitely an appeal for working with the same size format (11 space). I had also briefly thought of using the 3/4" format but that is way too drastically different. BTW, I think the Tonelux stuff is 1.1" for 16 modules in a 19" rack space. Very nice engineering but limiting at the same time. Mostly since the 3rd party modules for the 500 format are growing incredibly. Not so much for the Tonelux format.grantlack said:to keep the strange yet wonderful amalgam of size standards that the 51x project has fused thusfar, might it be considered to develop the buckets in the same 3RU, 11-channel configuration as the current 511 racks?...
Very nicely put. I mostly have no clue what I'm doing that's why the API is such a good fit for me. My short but first impressions of the SSL were a little cloudy and fluffy in the low mids. Maybe pillowy. It was very opposite of what I expected. It may also be due to the fact that API is so tight and focused in this particular area.fluxivity said:The E series was a great console, but I don't miss it like the API. the best thing about it was my studio had the loudest mixes in town, if not necessariy the best sounding. It made mic choice and placement a much more serious concern. The API is so forgiving, which is great for me cause I have no clue what I'm doing most of the time. It's amazing, it just does grows hair on the electrons as they go through it. The ssl gave them a bath got them all presentable for polite (radio) society.
you can have as many space versions like you want.jsteiger said:I will be asking Volker to do an 8 space version of his GDIY 51x backplane for our pre's, eq's and the like. Partially it's selfish as I need 4 of these 8 channel buckets for the eq portion of my new, discrete monitor section.
That was the secret of the whole thing. A little cut on the kick drum 560 to get it out of the way of the bass, a little cut on the bass 560 to free it a bit from the kick drum and that was that.It may also be due to the fact that API is so tight and focused in this particular area.
Cheers, Jeff
"You will need an 2503 (send to patchbay) and another 2520 (return from patchbay ) to unbalanced the signal again , and then go to fader and then to pan pot and the pan to buss also , and then later to ST buss or Submaster. (in my 528 that's the path ). "
Yes, correcto mundo boji. I have all of this taken into account and it's in the circuit...except the preamp out(send) is balanced and boosted 1:2 with 2623-1 not a 2503, just like my desk.boji said:"You will need an 2503 (send to patchbay) and another 2520 (return from patchbay ) to unbalanced the signal again , and then go to fader and then to pan pot and the pan to buss also , and then later to ST buss or Submaster. (in my 528 that's the path ). "
Isn't this already accounted for in his shema on page one?
