I was just about to post on here that I have made some nice headway on this project the last few days. I have been working on the 8 space, 500 series PCB bucket first. I have came up with a few nice options that will make it somewhat versatile and unique. Volker and I have been emailing back and forth about this as he has an 8 space version of the backplane pretty much done too.
I want to clean up my drawings a little so they are a little easier to understand. I have not asked Volker but maybe I will just post my drawings here to get other thoughts rather than he and I just have these discussions in private.
For a quick outline, the main backplane will be much like the 51x backplane and will also be able to accept the 15 pin connectors for standard VPR stuff. Connections to the outside world from the rear of the backplane are somewhat limited but enough. I am sticking mostly with the .156" Molex type connections. This will be the case for the busing modules and input modules too. Each slot will have a 3 pin .156" header for in and for out. There is also a 2nd .156" header for "B" input. For ease of understanding, I will say Line Input. This would be fed from a tape machine, PT or what-have-you-not. This "B" input and the slot's output go to a small, vertical plug-in relay (that I am also using on the VP312DI and elsewhere). If you have your preamps in this 500 series bucket, you could have a remote switch to activate the relay to select Mic or Line to feed the future Input Channel. This relay mounts with a .1" 90 degree header. It can be socketed or soldered directly. This small relay PCB mounts to the rear side of the backplane near the top of the slot.
Lets call that connection option 1.
The next possibility is more standard using the .156" Molex layout. Do not populate the B input header, forget about the plug-in relay, jumper across 2 sets of holes where the relay goes and you are in business, the normal 500 way only with Molex connectors.
The 3rd and last possible connection method, (which I need 4 racks worth for myself, BTW!) is using Dsub, DB25. I am doing this with a smaller daughter board that mounts using 3/8" standoffs to the rear of the 500 backplane. There will be 2 PCB vertical mount DB25 female receptacles on this daughterboard. I will be using 3M .1" headers mounted to the rear of the main backplane and 3M .1" female receptacles on underside of the daughterboard. I have 8 of the 3/8" standoffs between the 2 boards so it is a short distance and rock solid. The daughterboard is a necessity as there is simply not enough room to run the tracks for both DB25 connectors if they reside on the main board.
It is not possible to use the B input/relay set up and the DB25 daughterboard. The .156" connectors are also not used with the DB25 option. Volker has XLR's on his board. There is simply not enough room for them on my board. It's a game of sacrifices to some degree.
The main backplane is .125" thick, just like Volker's 51x boards. The daughter board is .094" thick so there should be very little flex from the 2 DB25 cables hanging there.
Enough talking. Let me make these CAD drawings presentable. A picture is worth a thousand words as they say.
Best, Jeff
Best, Jeff
