Potato Cakes
The ceiling control is an odd bird. Turning up the ceiling control will cause and increase in level that will in turn feed the compression circuit. Start with the ceiling control all the way up and then feed it signal. Then adjust the threshold to see if you can hear gain reduction. Also, just to be sure, make sure the circuit is engaged and the compressor is engaged (I've neglected to do this before).
Is this the first or second revision? Do you have a known working VCR2N?
Paul
Paul
