I think I found the proverbial smoking gun with these 525s.
The ones I built both had hum and a non-musical distortion (same as discussed on pg 14 by Mich and Peter). The distortion was not caused by the FET - it was caused by the meter circuit. After turning R55 all the way off (so the meter would not light at all), the distortion disappears. There's a ground problem when the meter circuit shares the same ground as the in/out pot grounds. I think the current from the meter circuit was causing a ground loop between in/out pots and A3. Easy fix - I cut the trace leading from the neg side of CM1 to the GND on the meter board, and ran a wire from Neg CM1 to audio ground at the hole by gold finger 5. With this change, both of my 525s are quiet & distortion free. Even at heavy compression they sound smooth - a huge improvement. And the hum is gone
A second mod I'd recommend - after tightening down the mounting nuts a few times (or a zillion in my case), the silkscreen over the ground plane developed shorts, which connects audio ground to the chassis, not desirable. Easy mod was to cut the traces by gold fingers 5 & 13 to disconnect the pcb ground plane from audio ground. Then the short to the chassis through the mounting bolts makes the pcb ground plane a chassis ground, which is better for noise rejection.
With these mods the 525s are fantastic. I just played through them with guitar and singing and they are smooth and clean.
