Jean Clochet
Post removed.
pultec with a 10K:10K, input might have problems with the tone circuit dragging it down?
JohnRoberts said:ruffrecords said:JohnRoberts said:While ability to drive 600 Ohms is a way to separate the men from the boys, so to speak, it is an archaic, obsolete, standard, kept alive by antique gear lovers. s.
Not entirely obsolete. If you need to drive significant cable lengths, as many studios, OB units and PA rigs do, then you need to ensure your driving source impedance is low enough. If your kit has for example a 1500ohm output impedance it will drive a 10K bridging input with no problems. However, use it to drive 30m of cable which has 100pF/m cable capacitance and you will be 3dB at 15KHz at the other end. Reduce that output impedance by tenfold to 150 ohms and the -3dB point moves out to 150KHz but the phase response starts to alter at 15HKz. For negligible phase shift at 20KHz under these conditions you really need an output driving impedance of no more than 50ohms. Now I know a low output impedance is not the same as drive capability into 600 ohms, but any amplifier with a 50 ohms or better output impedance will drive a 600 ohm load to a reasonable level.
Huh... apples and oranges,,, drive capability and source impedance are two different things. An audio power amplifier may drive 2 ohms but have a source impedance of tens of milliOhms.
Brian Roth said:Too bad the required circuitry won't fit inside of an XLR connector <G!>
AP carrier said:Hey Brian,
This 8 pack circuit board looks like it can be configured balanced input to balanced output with a 5532 or 2604 and trimmed to unity. Could be an option if you don't mind a bit more soldering?
http://www.jlmaudio.com/forum/viewtopic.php?f=2&t=164&sid=bd485d221e09cf01360667d56e86b9b1
Andrew
