skal1
abbey road d enfer said:Quite easy, since we know the input and output levels:skal1 said:Ok this what i have set up for the GR amp.
Signal gen out is .245 mVrms to primary of 600:10k tx , voltage across secondary is 1.016 Vrms ,this is injected into the grids of the GR amp which has a set down Ratio of 4:1 ,the voltage across the primary is 24 Vrms and the secondary voltage is 6 Vrms , this is without a load across secondary of transformer.
How would one calculate the db gain of the GR amp, please let me know if i am using the wrong terminology for the voltage , don't want anybody getting confused.
regards
skal
I guess you meant 0.245V or 245mV for the input level, so the actual overall gain is 6/0.245 or 24.48 or 27.8dB.
Since the input and output xfmrs have the same ratio (in reverse), the actual grid-to-plate gain is the same.
yes 0.245V, so whats 245mv is micro volts i'am guessing, where did you get the 6 from in this formula ( 6/0.245) and why did it get divided by the input level.
regards
skal
