rock soderstrom
Tour de France
Hi Bancho, where are you located? It makes really sense to add this to you forum account. Cheers
MRecords said:I have some troubles with my DI. I can´t get more than 13dB of gain.
andyfromdenver said:MRecord's post was addressed by IAN, and he mistakenly doubled instead of halved the cathode resistor for parallel operation.
hope that clarifies it.
CJ said:anybody verify the adj regulator resistors yet?
andyfromdenver said:ok, so 170-0-170VAC 40mA(center tapped, maybe obv.) or 340VAC 40mA (no center tap, bridge rectified) and 8VAC 2-3A (center tapped or not) That should work.
Because that creates the desired HT voltagebancho said:Sorry for my ignorance but why do I need 170-0-170 secondary?
OKI would make two DIs in two separate enclosures. Each would have its own supply.
It can be run at up to 250V but that does not mean you have to. The typical output is 2V rms. This means the primary of the output transformer has to swing by 8Vrms which is about 11V peak. This means the anode only has to swing down to 159V and up to 181V. Raising the HT to 250V is unnecessary and only result in more dissipation in the tube and a need for a larger mains transformer.I thought the tube is designed for 250V anode voltage and using 170V is kind of being on the safe side.
As a rule, the transformer needs to be able to provide an ac current into the rectifier that is about 1.6 times the required dc output current - so it needs to be able to provide 960mA; nearly 1 amp. If you had two in the box you would need 2AAnother question about the 8V secondary… you said it should take 2-3A current… why if the heater current of the tube is 600 mA ± 35 mA?
You need to add up the total primary VA and multiply by 1.1 to allow for the transformer efficiency. This is the VA in the primary. What current that represents depends on the mains voltage.And how much current should the primary take? The manufacturer said it is usually 0.08A - is that ok?
PRR said:> On the sowter page
Look *carefully* how they are specifying "VAC" for the center-tapped 2-diode case.
This appears to be incorrect (and also un-refuted). Thank you for spotting this. The 340VAC single winding FWB will give 480V DC, which is distressingly high. You need an >450V first cap. You can drop 300V with much bigger hotter dropping resistors, but that is inelegant. If you do not *know* this will give way-high voltage, it may be trouble. (Andy should check my math; then if valid edit his post.)andyfromdenver said:ok, so 170-0-170VAC 40mA(center tapped, maybe obv.) or 340VAC 40mA (no center tap, bridge rectified)
