evilcat
Very nice build remsouille!
remsouille said:Hey there fellas!
I'm about to complete my 6 channel unit, and I must say I'm quite pleased about the way it came together:
Can't wait to silkscreen it!!!
I used a screened power transformer to be able to put it in the case, and I have on ACDC for every two channels. All channels are functional, however I seem to have a little problem...
My 48v rail works fine, but when I tried to hook up two of the leds to one of the acdc's, the damn 47ohm resistor on the acdc blew . When I disconnect the wire that goes to the led - to 0v, everything's fine.
Resistance between 0v and chassis reads 3,7ohm on every acdc .
Anyone have an idea where I should look into?
Thanks!!
What is the value of the current limiting resistors to each LED ?remsouille said:I used a screened power transformer to be able to put it in the case, and I have on ACDC for every two channels. All channels are functional, however I seem to have a little problem...
Thank's a lot!!evilcat said:Very nice build remsouille!
KDE said:You forgot to screen print some numbers!
I used a 3,9k, as specified in martin's building instructions, although it's only a 1/4w which maybe might be the problem (?).Harpo said:What is the value of the current limiting resistors to each LED ?
Did you use single pole or dual pole switches for activating phantom voltage per channel ?
If dual pole, what is the LEDs supply voltage (with a free pole at the switch you might have used the unused negative rail for your LED supply).
If single pole, do your current limiting resistors have the power rating needed to stand the heat generated by (48V - LED Vfwd)*ILED ? If your build is missing these resistors, expect the LEDs to be blown once powered on. This short could also kill your voltage regulator, so double check, the phantom rail is still delivering +48VDC.
madriaanse said:Wow! VERY nice looking build Remsouille! Did you end up using the MPSA-18s?
Martin
desol said:What's the best output impedance for the signal generator to be set at Madriannse?
I suppose it should match the input impedance of the primary of the transformer...
madriaanse said:Does the problem preamp also exhibit these symptoms at 75dB? If so, you might have an oscillation issue related to transformer placement or not using shielded wire in the proper places. If it only does it at 70dB I'd check for improper resistor values around the switch or a possible solder bridge somewhere.
M.
dmp said:I'd suggest checking that the 10468 transformer shield is grounded to the chassis with a multimeter. I built one of these and without the transformer shield grounded it would feedback at high gain.
A quick test is to ground the input on the pcb to ground and see if the problem goes away.
