remsouille
- Joined
- Oct 15, 2012
- Messages
- 218
desol said:Do you have fuses on everything while you go?
Yup, it might be oversized though... what would be a good value for 6 channels with 3 acdc's at 230v?
madriaanse said:Sounds like all the 0V's are somehow, somewhere connected together between your different ACDCs? You don't want to do that.
madriaanse said:That actually looks ok, but since the 0V's are connected together, disconnect 2 of the 3 ACDC's from earth/chassis.
madriaanse said:The audio issue you're describing sounds like you may have input/ouput transformers too close together. Try experimenting with transformer placement.
spase said:did you tried to replace those wires?
dmp said:Seems like you have coupling / oscillating through the power supply rail.
Have you checked and tested your psu and made sure it is correct? Do you have a known good psu to try, like a DC supply?.
Do you have the correct caps in the power supply decoupling positions? i.e. c4,c5,c7,c8?
madriaanse said:Can you compare transistor voltages on the good channels vs the bad channels and report back? Pls see first post on what the values should be.
Also, are you able to look at the PSU rails with a scope?
M.
madriaanse said:It's a bit hard to see, but it looks like in the video you are able to make the buzz/oscillation go away entirely by moving the power cable. Is that correct?
remsouille said:-All channels only hum on the 55, 60 and 65dB positions when plugged alone (I'll check again, but it seems to get randomy when several boards are plugged).
- I unplugged one good board and plugged it to the in/out transformers of a bad channel, it worked perfectly, SO: the problem definitely comes from the boards, which makes sense, since, as I said, the two good boards were not assembled at the same time. I must have made one single mistake when I assembled the 4 bad boards together.
BUT, I just doubled-(heck, tripled)check every-damn-thing, and still don't get it. I'll see if I have enough bc184 left to populate one bad board, who knows, maybe I came across a bad batch of mpsa18... Any other ideas?
I did. They are.dmp said:You might verify that the tant caps are the right way. If their polarity is wrong all kinds of weird things happen.
