Ive got pots on all of mine. Dont really notice any noise per se but my guess would be it depends on the quality of the pot. And ps, being able to push that gain stage is awesome and well worth any noise trade off.
sr1200 said:Ive got pots on all of mine. Dont really notice any noise per se but my guess would be it depends on the quality of the pot. And ps, being able to push that gain stage is awesome and well worth any noise trade off.
http://www.hammondmfg.com/182.htmcritterkllr said:Can anybody recommend a suitable transformer alternative to the 62085-P2S02 listed in the bom? I've had 2 on backorder from Digi-Key for a month and just finally received an estimated lead time of December 19th. I have 2 x EZ1290s (plan on having 4 eventually) and have the JLM ACDC. Everything is ready to go waiting on the transformer. I'm a bit of a noob when it comes to PSUs.
Should this do the trick? http://www.digikey.com/product-detail/en/70085K/TE70085-ND/251503
Chrome Heart said:http://www.hammondmfg.com/182.htmcritterkllr said:Can anybody recommend a suitable transformer alternative to the 62085-P2S02 listed in the bom? I've had 2 on backorder from Digi-Key for a month and just finally received an estimated lead time of December 19th. I have 2 x EZ1290s (plan on having 4 eventually) and have the JLM ACDC. Everything is ready to go waiting on the transformer. I'm a bit of a noob when it comes to PSUs.
I thought the Amveco had dual secondaries. I see a couple of 22V torroids on the Hammond list that look like they would work. Maybe Im wrong. It wouldnt be the first time.critterkllr said:Chrome Heart said:http://www.hammondmfg.com/182.htmcritterkllr said:Can anybody recommend a suitable transformer alternative to the 62085-P2S02 listed in the bom? I've had 2 on backorder from Digi-Key for a month and just finally received an estimated lead time of December 19th. I have 2 x EZ1290s (plan on having 4 eventually) and have the JLM ACDC. Everything is ready to go waiting on the transformer. I'm a bit of a noob when it comes to PSUs.
Maybe I should have mentioned this is my first time building a power supply and have no idea how to calculate/design around a transformer. None of the hammond transformers I've found have the same specs as the transformer listed in the bom 62085-P2S02. Specifically, the Hammond's are all at 24V and the Amveco is 22V. Also, the Hammond's have dual secondaries, would I just wire it up with one of the secondaries disconnected? Is it a better choice than the pcb mount Amveco in my link?
wimmy7986 said:Awesome! Thanks for pointing out the hammond options. I think I've narrowed it down to this model... http://www.mouser.com/ProductDetail/Hammond/182L12/?qs=%2fha2pyFaduhkZsoALO1xLH8m%2fA88eyezwSWKx62QmIo%3d
There's also a 30 VA option
Can anyone confirm this will work for one or two channels? I'm a noob when it comes to power transformers, and just want to be extra sure... Thanks
795mA seems a bit on the light side to me. The 62085 in the BOM is 1.13A. I would opt to go higher than lower.critterkllr said:wimmy7986 said:Awesome! Thanks for pointing out the hammond options. I think I've narrowed it down to this model... http://www.mouser.com/ProductDetail/Hammond/182L12/?qs=%2fha2pyFaduhkZsoALO1xLH8m%2fA88eyezwSWKx62QmIo%3d
For one or two channels, Digi-Key has this in stock: http://www.digikey.com/product-detail/en/62075-P2S02/TE62075-ND/299875
Not sure if it will work, but it seems like it should.
Chrome Heart said:795mA seems a bit on the light side to me. The 62085 in the BOM is 1.13A. I would opt to go higher than lower.critterkllr said:wimmy7986 said:Awesome! Thanks for pointing out the hammond options. I think I've narrowed it down to this model... http://www.mouser.com/ProductDetail/Hammond/182L12/?qs=%2fha2pyFaduhkZsoALO1xLH8m%2fA88eyezwSWKx62QmIo%3d
Seems a lot over the top. A 1290 will draw 125mA of DC current. 250mA for two. Add current draw of enabled +48VDC phantom rail 2 Ch.* worst case 14mA * form factor 4 from voltage doubler circuit, current draw of voltage regulators network and some status LEDs on top, the 795mA AC current of the Amveco 62075 with paralleled secondary windings seems sufficient for two channels, delivering up to 795mA AC/form factor 2.3 from halfwave rectifcation=345mA DC. As always YMMV.desol said:You want 350-500mA per channel.
I can't recall exactly the value, but I want to say the inrush was quite a bit higher.A 1290 will draw 125mA of DC current
Page 84 of the thread had a discussion on that topic recently.critterkllr said:It seems like a lot of guys don't have access to an oscope and signal generator. Did anybody do a before and after to test the difference between biasing correctly and the ballpark voltage listed? I hooked mine up before because I let somebody borrow my oscope. It sounded good before, but after biasing seemed to sound wider with more of the signature pronounced chunky low mids. Sound went from very Neve inspired to Neve.
Just wondering if others could share their experience so people without a scope could potentially make some adjustments using their ears.
Chrome Heart said:Page 84 of the thread had a discussion on that topic recently.critterkllr said:It seems like a lot of guys don't have access to an oscope and signal generator. Did anybody do a before and after to test the difference between biasing correctly and the ballpark voltage listed? I hooked mine up before because I let somebody borrow my oscope. It sounded good before, but after biasing seemed to sound wider with more of the signature pronounced chunky low mids. Sound went from very Neve inspired to Neve.
