Hello,
I am planning out an 8 channel build of the NYD 12av7 one-bottle preamp, and I am a little stuck on the heater supply. It seems, from my research, that a DC supply is best for a first-stage preamp tube. Having explored the possibilities for a linear supply and losing my mind to PSUD2 in the process, I renewed my search efforts and found that some forum members (Mr. Thompson-Bell, for example) use SMPS supplies for high current DC heater duties. 8 12av7 tubes in parallel would need 6.3v at .45A per tube, making for 3.6A total. The most optimal supply then must be around 10A and adjustable to 6.3v. Do I need any additional circuitry to adapt an SMPS to this use, e.g., LC filter? What should I know about SMPS power supplies thus implemented?
Edit: It seems the closest voltage is 7.5v; I guess a dropping resistor might work?
Is this supply OK? https://www.mouser.com/ProductDetail/MEAN-WELL/RSP-75-7.5?qs=JK6Bpmia/muWwvY9i8JHNw==
