netnoggin
Member
One more (important) update. Skylar mentions on the drawing that phase may be reversed. I just ran some tests on this and can confirm he was correct to be concerned. What I found out is some inputs are out of phase with others if wired using the polarity indicated. At this point I don't have a way to know which ones are "correct" and which aren't, but they should at least be all the same.
Here's the way the drawing lays it out (pin number designations follow the standard layout for this class of connector):
J2
Pins 1,2 - ch1 +,-
Pins 4,5 - ch3 -,+
Pins 7,8 - ch5 +,-
Pins 10,11 - ch7 -,+
J3
Pins 1,2 - ch2 +,-
Pins 4,5 - ch4 -,+
Pins 7,8 - ch6 +,-
Pins 10,11 - ch8 -,+
What I found was channels 1, 2, 5, and 6 are indeed out of phase with the others. I reversed those connections and they now all test the same. This really makes sense if you look at the way it turns out, pin-wise.
I will at some point try to figure out how the phasing compares to other equipment, but I thought I would pass this info on right away.
J2
Pins 1,2 - ch1 +,-
Pins 4,5 - ch3 -,+
Pins 7,8 - ch5 +,-
J3
Pins 1,2 - ch2 +,-
Pins 4,5 - ch4 -,+
Pins 7,8 - ch6 +,-
