mitsos
- Joined
- May 4, 2007
- Messages
- 2,886
I looked at the 160X schematic and I still think the lower RMS is only going to the meter, but I can't see how the signal gets to the upper RMS detector... :
Was this jumpered to the input like the 903?
Anyway, one pole of the switch seems to switch between the outputs of 105A alone and 105B + 105A through a 1K resistor. The other pole connects one input of one of the LM339's to the negative rail, I think, turning on the "above, easy, below" LEDs. But I don't see any change to the GR metering at all. Someone with a degree please step in!
Hard knee would mean the CV would ramp up to full value quicker and closer to the threshold, whereas the overeasy is supposed to slowly start ramping up before you actually hit the threshold, IIRC.
