Thanks for this abbey. It's the main article I was trying to find. Some new SRCs have been added but the only new member of the elite group is Apple CoreAudio(Leopard) Have a look at this to see what good SRC should be like. No visible aliasing and the intermod this introduces down to -150dB. Only Logic 8 (Leopard) seems to have taken advantage of this.abbey road d enfer said:http://src.infinitewave.ca/
Actually hardness of cymbals is caused by not having enough roll-off cos the aliasing and intermod.So the designers make their choices. Some privilege transient response at the expense of out-of-band attenuation or HF extension, some privilege roll-off at the risk of being criticized for the harshness of cymbals ...
I've conducted Double Blind Listening Tests bla bla on several of the tested parameters for other purposes and will put money that some of my panel can reliably detect the aliasing and intermod on certain (musical) signals. These people (the best ears I know) will not be able to detect some of the other stuff like transient response except under highly artificial conditions.
On the subject of real-time SRC, don't we now have enough processing power to upsample to the Lowest Common Multiple? Excuse me if this is a stupid question but my (pseudo) DSP knowledge is firmly 20th century.
Rochey, could you give us a firm (or official) opinion? Which is TI's best A/D?
Sam, is this your measurement or a claim? What device is this?My best DA converter so far gets to 130 dB dynamic range in a 22 kHz measurement bandwidth.
I can answer that. The Sony PCM-F1 had textbook 16b dithered performance. You can take a sine wave 20dB below the noise and still hear (after suitable amplification) a clean if noisy sine wave. If you switch the F1 to 14b EIAJ, it is improperly dithered and you get the crackling, loss of signal and noise modulation well before you reach the noise level. Piano music is good for this test too.One nuance or subtlety surrounding dynamic range discussions for A/D/A is the classic analog definition (peak signal to noise floor) ignores what is going on below this nominal noise floor. We can hear signals that exist below this nominal noise floor so there is another signal floor down at the quantization limit. How far this quantization occurs below the noise is probably audible if close.
I used this in da early days to prove to others (& myself) that this digital stuff was pukka.
This is a simple test for a 16b converter not needing any gear except an attenuator, hi-gain line amplifier and your ears. IMHO, a codec which didn't do this is unacceptable. Unfortunately, if you look at the Rightmark website, you see many soundcards & recorders that would fail.
Some commonly available examples of good 16 codecs today are the Line I/Ps on IBM / Lenovo Thinkpads going back to at least the T22.
In theory, low distortion quantisation (visible by averaging over a zillion seconds) is available a zillion dB below the properly dithered noise level but piano -20dB below noise is a good practical benchmark.
