gary o said:Interesting Isnt the vintage U87 i polarisation voltage around 46V ish, lower than the 60V in the more modern Ai U87.
I read several peoples opinions that that is the reason its sounds better, better low end more musical sound due to more relaxed diaphram, Im aware or the noise penalty.I was thinking maybe thats why this crappier capsule sounds good in the 87i circuit.
ehhh...
Less read more work.
Reading about someone subjective feelings, for me, is worth the same as reading teenage girl diary...
These statements could be worth anything if they will be about flat circuit.
Two main capacitors in deemphasis circuit are different for both version of U87...
gary o said:A while back when I got the cheap K67 I tried it in a valve mic with 60V polarisation voltage & plate to ground caps installed & it didnt sound good, to me all my DIY tube mics have more detail in the high end than any of my FET mics I thought this well contributing to making it sound shrill.
Because all depends on the circuit. That's why i don't agree with all universal "recipes".
For example my G7 with k47 "type" capsule is polarised by 50,5V. In this circuit it sounds the best. Same capsule in other circuits sounds best at 60V, 65V, 70V etc.
gary o said:Im going to re try the cheap K67 in a Ela mic I have as I said I already have the plate ground caps installed I have a 3 way switch cant remember the values I those, think one value same as K49 other same as original Ela s cap value & maybe something inbetween, i will check.
What's the "value same as K49"?
If you want a hi-end mic don't spend time here go to tweak
