Matador
A cap on the plate to ground is not quite the same circuit action as is employed in the U87: the U87 is done through negative feedback, not simply filtering certain frequencies to ground.
U87 injects an out-of-phase sampling of the output back through the polarization network. The feedback increases as frequency increases, which means the closed loop gain has a pole in the response and gain is reduced at about the same point that response is rising through the capsule.
I don't see why a similar technique can't be done with a tube circuit: you could tap from the plate (which will be opposite in polarity to the incoming signal), and then figure out a way of coupling that signal back into the polarization string.
