Got the power supply and preamp section rebuilt. Tried splitting the output transformer on one channel for a direct output. It does work to give two isolated outputs (one for direct out, one for mix bus), but the gain loss is too much. Not worth it as the direct out doesnt have enough gain to drive my tape machine inputs to full level. Taking a direct out from the full 500ohm secondary works much better.
So im thinking the final topology will be:
separate mic and line (32db pad) inputs -> mic/line switch -> phase switch -> preamp -> direct out/mute/mix buss switch (will use the original program/off/monitor switches) -> daven -> NYD 600ohm pan circuit -> output amps
The direct outs will have their own 500ohm T attenuators, so you can set levels independently for direct outs.
i will add in an echo send similar to the UA610 on each channel, and add in a 6sn7 for makeup gain to drive an echo output.
This means to go from tracking to playback you have to flip two switches (mic/line and direct out/mix buss) for each channel. And when using the direct outs, you cant monitor that channel. I suppose I could use one of the extra console switches to send the echo output to one of the line input channels. Then you would have a way to monitor a channel when switched to direct out.
I also bought a couple Hammond 119DA (600ohm:4/8ohm) transformers which I will use to drive passive monitor speakers direct from the console. Will use some of the extra console switches to make make the speaker outputs switchable on/off.
Cheers!
Tyler
