ADK A51-TL internal wiring problem - Help needed
maxkriza
uk
Hi
Got this faulty mic. all the 3 wires from capsules to pcb are disconnected.
Can't find a schematic for it or an internal pic so I can resolder these.
will appriciate any help
thanks
Max
At a guess, backplate to 1G resistor / ~1n cap junction. Front and back diaphragms.... Well, it's hard to see on this iPhone screen.
ok, mic is now working but only as cardioid. I've connected red wire to the cap that goes to fet gate,  yellow wire to earth. back capsule red is connected to the other pcb as seen in the pic but mic is not
working as multi pattern only as cardioid. any idea why? .
Is there a similar circuit that I can use as a reference ?
thanks
Max
yes , still wating for reply.
do you know of any similar mics that I can use as a reference?
thanks
I tested both capsules, they are both working individualy. back one is connected to the same
spot it was before, going to a cap which is connected to the multipattern switch, there is
voltage on the back capsule. mic only works as cardioid though.
thanks
max
problem is solved now.
yellow (common to both capsules) goes to fet trought a cap.
red (front capsule) goes to earth - that was my mistake !
other red goes to the polarity switch trough a cap.
mic sounds great now in any position.
thanks to everyones input.
Max
