aes to s/pdif converter
ootermind
New member
new york
hi, anybody know if it would be easy and cheap to build an aes to s/pdif cable (and s/pdif to aes of course)? any loss in signal quality? thanks.
You know the format isn't the same but close enough for most purposes, right ?
From AES/EBU to S/PDIF is easy:
http://www.epanorama.net/documents/audio/spdif.html
(the following copy/paste will be distorted, but you can see it can be done easily)
Code:
AES/EBU to S/PDIF signal level converter
AES out:   2-------330 ohm-----+-------------   SPDIF in
           3--+              91 ohm
           1--+------+---------+-------------
                ground
(Thanks to MCS)
Bye,
Peter
[quote author="clintrubber"](the following copy/paste will be distorted, but you can see it can be done easily)[/quote]
Use code for that
Code:
           3--+              91 ohm
                  ground
Best regards,
Mikkel C. Simonsen
To connect an S/PDIF signal to an AES/EBU input, this should work:
Here's a quote from my DA-12 page:
It works just fine with S/PDIF signals. Just connect the inverting input to ground through a 10n cap and connect a 237R resistor from the input to ground.
It works with the Crystal receivers at least...
Best regards,
Mikkel C. Simonsen
