Spencerleehorton said:
The dilemma I have about it all is that I want to supply 2 mics from within this one psu.
I have a 2.5 a 24v txt for the H+ and a 188v 0.410ma for the B+.
Hopefully this can supply both mics?
Assuming you mean 410mA and not 0.410mA, then yes these should be fine.
I am having trouble tracking down a 15w 100R or 120R is there any other wattage pots I could use?
I just found a 100R 10 watt pot, I'm hoping this will be ok?
Well, let's see, it looks like the original pot may be over-specified, perhaps due to limited selection of components. There's about 125mA going through it. Power = Current Squared x Resistance = 0.125 x 0.125 x 100 = 1.56W but it will be inside a case with poor ventilation and other things getting hot like the PNP transistor and the trafo cores, so we should go bigger and 10W will do it happily.
I am also still unclear how this arrangement comes down to 5v at 122ma.
Matt Nolan said:
Figure out the approx trimmer potentiometer setting in advance using Ohm's Law. R = (Vzener - 0.6) / 125mA
The PNP / Zener circuit is a constant current supply. It works because so long as we are in the normal operating region of the PNP, it will develop approx 0.6V across the base-emitter junction. So long as the Zener is in a good point on its operating curve also (they're running the original at about 20mA, I think) then it will have a pretty stable voltage: its specified voltage. You might want to look at the I/V curve of the Zener you pick, and adjust the 1k R2 if need be, to put it in a nice place on its curve.
The base of the PNP and the low end of the Zener are at the same voltage. The top end of the zener is 9V (or 12V) above the base. The emitter of the PNP is 0.6V above the base. So, the pot has to have the difference between these two voltages across it - i.e. 8.4V (or 11.4V).
So, if we have a fixed voltage across the pot then the current through it will be that voltage divided by its resistance. Turning that around, you can set the current by varying the resistance. That current splits to go to the heater (which wants 122mA) and through the 2k bleeder resistor (which will take 2.5mA if the voltage is 5V). 124.5mA in total. You could practically ignore the bleeder resistor in your calculations.
The current requirement is set by the heater. The AKG engineers found it best to run it at 5V, at which level it draws 122mA, or thereabouts. We learn this from your schematic. Most likely this is the point of best SNR for the mic.
The current is held constant (within reason) even if the resistance of the heater fluctuates (which it will - lower resistance when it is cold, higher when it is hot), so this is a nice semi-soft-start circuit really - it stops a high current spike going through the cold heater when you first power up. The current is also held constant (within reason) with variations in the supply voltage, due to the constant voltage action of the Zener and the PN junction in the transistor. It's a little feedback loop. The resistance of the transistor emitter to collector path will vary to try to keep the current constant.
I hope that all helps.
Matt.
