Matt Nolan
Swap that 3k3 for a 6k8 (oddly enough, what my earlier guesstimate was), or stick 2 x 3k3 in series there.
I don't know what the lorlin looks like that you are using. Look at the schematic and look at the pin diagram of the lorlin. Reconcile the two.
You should have 56k resistors between the consecutive "throw" connections, the bottom one also grounded, the top one also to B+. The "pole" connection of the lorlin goes to the 1Meg.
If your switch is something like this - http://www.lorlin.co.uk/PDF/CK.pdf - then you should have 56k resistors 1 to 2, 2 to 3, 3 to 4, 4 to 5, etc. up to 8 to 9. "A" to the 1 Meg. 1 to ground and 9 to B+ (or vice versa).
