I know you commented on another post, but the information there is not accurate. In my experience, every AKG D12 has a bass chamber, regardless if there is a tranny or not. Sure, the tranny sits inside the bass chamber, but there is still a bass chamber behind it. so the part underneath the capsule itself is both: bass chamber and transformer housing. But yes: THERE ARE SOME OEM D12's that have such a big transformer that the bass chamber is stuffed so much the low end isn't as good as on a standard D12. As far as I know this can only be found in Norelco, Philipps and probably some other OEM D12's.Hi, I have a 200 ohms D12 with transformer, and was wondering if i have a bass chamber or not. Recentered the diaphragm and got no further in the lows than what you can see in the freq response. Maybe i have an early one as described above? Is there a way to figure that out?
Yup, definitely. But we don't know how you got that eq curve. With a sine sweep? It is not so easy to get accurate results with that method...There’s some low end Loss for sure,
It’s like it has an High pass filter under 120hz
Just a regular older D12: both a stepup tranny from 60Ohm to 200Ohm AND a bass chamber, all in one housing. Your low end loss has nothing to do with the chamber neither the tranny.Looking at 1 photo one would say there is a bass chamber, looking at the other they built the transformer into it
So maybe it!s a smaller chamber?
If you follow the method using a signal generator to drive the diaphragm, it's pretty clear when you have the diaphragm aligned without any interference. If you started with the red (-45dB @ 80Hz), and improved it to the plot from yesterday (-13dB @ 80Hz), I'd expect the signal from the generator cleaned up a lot. Is this all true? Can you sweep 20-100 Hz and hear a clean sound produced by the mic?By realigning i ment that as described earlier in this thread i was able to get way more low end by loosening the 6 screws and moving the diaphragm a bit. Even loosening was already a big difference. I started with the red graph!
I tried this method befor with no success. I don't saye that it can't work, but it is not the whole story. The question in the first place is: Why is a diaphragm not aligned? It is because of magnetic dust that has been on it for many many years. The dust deformes the diaphragm. Sometimes you see clearly, sometimes you don't or it even deformes it in a concentric way, but still: the "headroom" is no longer available, you need to get thicker paper shims underneath it or correct the form with a heat air dryer.If you follow the method using a signal generator to drive the diaphragm, it's pretty clear when you have the diaphragm aligned without any interference. If you started with the red (-45dB @ 80Hz), and improved it to the plot from yesterday (-13dB @ 80Hz), I'd expect the signal from the generator cleaned up a lot. Is this all true? Can you sweep 20-100 Hz and hear a clean sound produced by the mic?
Then it is a diaphragm problem. You can forget about the bass chamber stuff until the diaphragm is moving freely.Now i can get a clean tone down to 90 something Hz. If i go lower it rattles.
As low as possibly when you can clearly hear it. Start with the generator at minimum and slowly bring it up. Driving it too hard could damage it.Point is, these low clean tones come wit the diaphragm pretty loose, once i tighten the screws it's no difficult to go back to the red graph
What's the level of the tone you feed the mic? Maybe i'm overmodulating
But as I say: it could be that the diaphragm can't move enough because there is not enough headroom for it to move, it could also touch the motor, not only the voice coil in the magnet gap. Or so do I think of it. Maybe I am wrong.Then it is a diaphragm problem.
I am helping the OP stop worrying about the bass chamber, realize his diaphragm has a problem, and not go beyond that until trying the alignment adjustment many times. Taking the diaphragm off is a good way to make the mic unrepairable. If it is still unsuccessful many times, could then try a thin piece of paper to shim the dipahragm up. Taking the diaphragm off to try to clean or adjust the VC is extremely hard. It would probably be better to send to someone with expertise at that point.Yes, there can be several reasons why it is not possible to get the diaphragm in a position that allows clean movement. The worst is a deformed voice coil or contaminants in the VC gap.
No, that I didn't wanted to say (english is not my native language). I just try to explain, that a diaphragm problem in most cases can't be solved by just realign it. if it was pressed down by magnetic dust, it doesn't work to recenter it, because the diaphragm is always to close to the motor.I am helping the OP stop worrying about the bass chamber, realize his diaphragm has a problem, and not go beyond that until trying the alignment adjustment many times. Taking the diaphragm off is a good way to make the mic unrepairable. If it is still unsuccessful many times, could then try a thin piece of paper to shim the dipahragm up. Taking the diaphragm off to try to clean or adjust the VC is extremely hard. It would probably be better to send to someone with expertise at that point.
Strange, on a good one you'll be able to clearly hear the sound down to 20-30 Hz.I managed to get distortion free tones till 60 Hz or so, below that the sound is so faint that it's difficult to interpret.
Yeah, and if you hook the signal generator up to the MD441 you'll see what I mean - you'll clearly hear the sound down to 20 HzThen i thought maybe the published freq response of the D12 is measured with more proximity. In my setup the mic is some1.6 meters away from any source. I measured a MD441 ( pink) in the same position and bang, lots of bass.
I don't think so, you just want the diaphragm to be able to move freely. You do need to tighten the screws holding the diaphragm down.I.e. is it necessary that the diaphragm placement is airtight? Maybe if there is a leak in the shims the bass chamber resonating effect could be diminished or diaphragm cancellation effects occur?
I don't know what all the dirt should be inside your mic?I have a D12E thats been suffering for a bit now, wondering if anyone has some good instructions on disassembly of the capsule, it seems really convoluted in here and the felt is just EVERYWHERE inside..
never mind... i freed the capsule from the suspension figured i couldnt do anything with it and just checked the screws around the diaphragm (which mine has a weird felt thing over)... all the screws were VERY loose. I tightened them up and the mic now picks up below 30hz again.... whats that about?!
whatever the felt like substance is inside the mesh is just weird. never felt (uh the pun) anything like it Just really strange. And yes, its like a black piece of cloth thats shaped over where the capsule should be. This seems to almost have its own ring with some golden paint or glue holding it on and then theres this grey paint or glue holding the second layer on (along with the screws). I dont think im gonna mess with it too much now that it seems like the mic is actually picking up correctly.I don't know what all the dirt should be inside your mic?
Over the diaphragm is a resonator that has (depending on the model) sometimes has a piece of felt or some sort of fabric over it. This is a 2nd pop filter, resonator and dust cap in one piece.
