[quote author="Freq Band"]
3 QUESTIONS while I'm here....
1) Regarding the Voltage Check doc.....it says to check IC#1 with no NE5532, then with it installed.....but do I leave #1 installed when going on to IC#2, leave #2 in, and go to #3 ?....in order?.....or is there no real order, and each IC voltage check is not dependant on there being other IC's installed?
2) I have built a seperate +48v PSU.
http://members.aol.com/ecc81/ps48.html
Should there be any ground connected to that. If so, where to where ? (transformer has no ground leg on the Primary)
3) (nevermind, found answer)
=FB=[/quote]
I still wonder about the above Q's ?
Also new Q:
My first voltage check (no IC's, all empty) resulted in skewed #s...here they are :
IC#1:
SHOULD BE NEAR:............WHAT I HAVE:
1) 0v...................................2.09v
2) 14.8................................12.9
3) 12.2................................11.87
4) -15.2.............................. -14.5
5) 12.2................................11.9
6) 14.8................................13.8
7) 0.07................................5.7
8) 14.8................................14.5
IC#2:
1) 0.07................................5.7
2) 0.07................................5.7
3) the rest are ok.
IC#3
all ok.
Meters' led's are all lit.
Same results for both boards.
Could it be I have the (bc550/560) transistors backwards? I'm using the NTE123AP cross ref. part here. The data sheet for these is VERY unclear as to pin assignments. I cannot tell if the NTE diagram is a front/top view or....See here:
http://www.nteinc.com/graphics/diag9a.gif
I could not locate the bc550/560 parts....but I do have some 2N3904/3906 parts laying about..???
help greatly appreciated !!! Thx
=FB=
=FB=[/quote]
Also new Q:
IC#1:
IC#2:
3) the rest are ok.
IC#3
all ok.
=FB=
