I powered up 2 channels of green. The higher voltages (13-16v range) check out normal but the low values start low and gradually drop down to zero as the channels warm up?
Has anyone else had this situation? Is it a problem?
I pasted in a table with Peter's reference in the first column, and my 2 channels in the next two.
Peter's starting voltage: +14.8, 0 -15.2
My starting voltage: +16, 0, -16
The Strange Behavior Starting with pin 7 of IC1, my initial measurement immediately after power-on is .25. Every few seconds it drops to .24, then to .23. then to .22, .21 etc.
Once I get down to .09, the voltage drop goes more slowly. I leave the probe attached. Over the course of a 3 1/2 minute Hall & Oates song, the voltage eventually drops to .01, and then to .00, occasionally hitting .01 again for a second, then back down to .00.
Same behavior with pins 1 & 2 and 6 & 7 of IC2 and IC3.
If I wait long enough, they will eventally drop to 0.00 volts.
So I labeled them as either ".09 drops" for example or just 0 depending on how long I waited before measuring (see table below.)
This is with no rotary gain switch connected, no output fader connected, and no pad/phase/HPF switches connected.
Any thoughts? Thanks for your insight. I'd love to hear if this has happened to anyone else - or theories of what is happening here.
Thanks! Kato
