Hi,man-bot said:Hello - I am finishing up a 4 channel green pre and everything has been working great up to this point.
Last night I wired in the 3rd channel, and it passed audio and everything worked fine but the metering - but I remembered the LM339 in that channel had been swapped with another channel's LM339 because it was bad (so the one installed was known to be no good). Popped a new one in and now I get a lot of noise and the the resistors on the attached PDF (thanks Frank) are burning up (with or without the LM339 installed).
Any ideas?
peterc said:How do the DC voltages on the IC pins compare between the 2 channels?
SmitH said:The 100k trimmer has no effect on pin 14 or pin 7 of the TL074
And there is 3.2volts coming out of pins 5, 7, 9 & 11 of the LM339
OK. I've looked at the docs. I'm a bit confused. I want to monitor before the output trim. So I've soldered a wire from the hole above the 20k trimmer to the hole at the right end of the silkscreened link above and left of the 100k. Does the small silkscreened link above it need to have a wire in it?
