college101 said:Hey MARK...should I be trying to add the 1000V dc blocking capacitors to the tester?
On mine...There is no ground to hook #10 up to..So I have to just tie it directly to seprate chassis ground..which then connects to the neon...
college101 said:OK..the CT which goes to #3 on TB#1 of the input...the input TB, has audio going to the CT? Is this correct?
It is in the middle of the winding...but #10 is connected to a isolated turret point, and that point is tied to the ground the connects to the NEON ground...
SO..when I have the tracer set up, No signal is going to R6..even though they are connected...
YES it is tied to a insulated turret point that is connected to the NEON ground...SO I need to remove the turret point, tie R5 bottom side to ground, and then re-solder it in place with #10 then...?
