college101 said:Thing is, the CT on the primary of the input, has to be grounded in order for me to get signal at R5.R6 test point...The CT shows in the schematic, that it floats... not grounded...
Ok, let´s disconnect the 1009 and test it!
Connect the COM lead (black) of your DMM (OHM setting) to one of the leads of the 1009, measure the other leads and write the results down.
If you just get readings on one lead and the other three show no connection, you´ve found the secondary winding.
If two leads gets readings, you´ve found the primary.
The secondary should have a much higher resistance (Ohm) than the primary.
To find the CT, find the leads (from the three) who have the highest resistance when connected to the DMM. The lead left over from the three is the CT.
