I just went to the studio to do some more testing.
First off, it sounds good! Its wild how hard you can hit this thing without it sounding bad. In fact, I couldnt make it sound bad, I tried.
I tested four different tubes in V1.
Plate voltages:
Cheap 12AX7:100/104
Old Fender branded 12AX7: 98/101
Random Fender 12AT7: 78/84
Mullard 12AT7: 50/57
Sound wise, the higher the plate voltage the higher the output (I left the settings the same), which makes sense. But once I level matched them, the were as follows:
Cheap 12AX7: didnt do a listen test
Old Fender branded 12AX7: little muddy in the lows and low mids, bright
Random Fender 12AT7: slightly muddy with clean high end
Mullard 12AT7: clean low and mid with a smooth top end
So I dont know what the deal is with the lower voltages on the 12AT7s and the Mullard in particular. I dont know if this is a problem. I could always lower the plate resistors (R9, R13) to bring the plate voltage up, but I dont know if thats the right thing to do, or even necessary.
Plate voltages:
Cheap 12AX7:100/104
