Looks clean!Phew, done the rewire of the heaters now.
Yep, tube-noob here, so thanks again for the direction!
Doing it properly is so much trickier handwork with the wires across vs around the socket.
Not much room with the awg20 solid I’m using, making me a bit worried about the insulation touching the other pins’ edges.
I threw on some heatshrink on the parts that sit between pins, but still.
What gauge do most use?
I WANTED to use my nice cloth 18 solid but there’s no way I could keep the twists consistent across the sockets. Just too fat, like me!
Anyway, here’s the “across” layout. Since pins 4 and 5 are connected, would it matter if the wire went to pin 4 OR 5?
It shouldn’t matter if the pins are jumpers together which one you go to with the actual wire. I usually just strip a bit longer lead of the heater wire and jumper it with the lead itself.
You do want to make sure your heater lines are consistent from tube to tube though (don’t switch back and forth between which run of the pair you are connecting to the particular pin)
Hope this answers your question.
