Dear all,
A couple of days ago I finished building my LA2A and (of course) I've encountered some problems. Here's a list of things I found:
- audio output is way too high - I'm feeding it into my mixer and as soon as the gain pot is higher than about 20% I get a clipping indicator in the mixer. Is that normal?
- meter seems to work in "output+4" or "+10" mode.
- it does compress when I turn the gain-reduction pot clockwise, maybe up to 10 dB.
- I can't get the meter to 0 dB in meter-compress-mode:
the highest I can get it is to - 3dB with R4 set to 0. However, then the neon lamp is off... is that normal??? Furthermore, the neon is only glowing for R4 between 30% and 70%.... is that supposed to be like that? I've tried the "matching resistor" protocol in Jahnsen's appendix (replaced R25 with a 100K pot etc), but it doesn't help....
- I've used Jensen transformers (JT-11P-1 input) and JT-10K61-1M (output) with the corresponding changes in the schematics (as indicated by the Jensen datasheet - basically: R5=11K, R17=680 Ohm (!!), R18 and R20 are both 330 Ohm, C5=22u).
- For all other component values I sticked to the ones in the original (?) United Industries LA2A schematics (1968)... I'm beginning to wonder whether that was a mistake? Should I have used D. Jahnsen's values instead?
Some of the voltages just don't seem to be correct, but I can't find what's wrong... here's some of my measurements:
point measured: without tubes ; with tubes (should be)
- main voltage (at R29): 370V; 242V (275V)
- pin6 (6AQ5A): 146V; 48 V (100-137 V)
- pin2 (6AQ5A): n.d.; 1.9 V (7-7.5 V)
- pin5 (6AQ5A): 146V; 149 V (114-138 V)
- pins 1,6 (V3): n.d.; 80 V (107 V)
I'd be extremely grateful for any help!
Dino
