[quote author="fum"]allright, need some troubleshooting wisdom.
One of my la2a's is doing this thing that I need to track down.
At random time intervals, it will make a pop, and then go back to merrily workin fine.
It could be 5 minutes, 10 minutes, etc., between pops. Sometimes two pops within 15 seconds, and then some time gap before it comes up again.
thoughts?
regards
ju[/quote]
Fum,
Try the easy stuff first:
- Change 1 tube at a time.
- I think the LA-2A will work without the T4B installed so you can try that to eliminate it being the cause.
- Take it out of the rack & open it up, turn on, pass signal & listen while "Carfully" poking around & wiggling tubes to see if you can find it.
I find over %50 of my problems with guitar amps this way... give it a little beating to make sure it's tight with good connections.
You probably knew all this... just trying to help.
Kevin (The guy you helped last year with my LA2A... it's been kickin ass ever since, Thanks again for the tips)
