imo
I am using the allied power transformer supplied with the Bloo kit(6K88VG). I have the whole unit hooked up, have gone through the wiring a couple of times and I am pretty confident that everything is where it should go. Upon powering up I noticed a funny smell, neon didn't light, so I turned everything off and checked connections again. I noticed that I was getting continuity between ground and the B+, measuring between turrets a 22 or 23 and ground. I disconnected the transformer and found that the continuity was coming from the transformer itself, between both (250v)red's and the red/yellow center tap, as well as between the greens(6.3) and the green yellow center tap. I had the power transformer hooked up as I think it was supposed to be, one black to turret and switch, other to neutral on the power inlet. One red to turret a22, other red to turret a23, green to a24 and a25, center taps of both to ground terminal between the 2 33u power caps.
Once I took the power transformer out everything else tested right for contintuity throughout the unit. I hooked the transformer up, this time only to the inlet and switch, and tried measuring AC volts between center tap of the 250 and either of the red wires. I got a negligible reading. Also the smell that I had smelled the first time was there, definitely coming from the trannie. It was really hot to the touch. I am thinking that somehow the transformer fried. Does this sound copasetic? I have built quite a bit of equipment, but generally non tube, using small toroidal transformers. I am a bit psyched out by this and wanted to make sure that I proceeded carefully. Any ideas or directions would be taken quite gladly
Peace
Peace
