hi there ,
the meter section can be a bit of a problem ,
one of the common mistakes can be the meter switch it's self.
if it's an on -off - on with a midle position in the throw , those often don't
work.
the wireing is easy , but can be confussed .
your meter might need the diode rectifier configuration.
the most common mistake is a wire is loose, or the shield jacket
is shorting one of the pots .
check for solder or tiny wires shorting the pots or switches.
check your HAX GND make sure its soldered.
turn your stereo adjust pots / limiter response pots full clock wise or
full counter clock wise , one of those positions will bring on the juice.
g.
