Timjag said:Hehe, Yeah with transformers in the monitor path you might end up making a terrible sounding album like Rubber Soul or Kind of Blue
If only it were that simple.
ruffrecords said:Thanks for your input Nick. It is all too easy to get dragged the the road of creeping featurism ....
.... Monitor section can be considerably simplified because solo allows individual channels to be monitored so it can be little more than a master bus/2 track playback switch and a stepped level control and a couple of meters.....
pvision said:I think if you created a tasty "tube" channel strip with mic / line, EQ, insert and a line out you'd find takers
How many takers you'd have for a full-featured monitor / speaker switching / output section I don't know, but it would be fewer
Timjag said:Personally (again) As someone that might use this kind of console I'd rather have some transformer colour, than farting about with cable capacitance, just for some type of purity that is subjective anyway.
scott2000 said:Would polarity flip on the channels be useful and also maybe allow for some type of mid side experimenting??
I see it was already brought up...... :-[
pvision said:Your pre-fader effects send & direct out are also pre-EQ in that diagram
Nick Froome
bluebird said:You are right about the unbalanced input. Its not a robust (or responsible) solution. The extra PCB is a smart "compromise" but a lot of work just to allow for a less than optimal solution.
My three way rebuttal:
1. The balanced direct out is a must. So your half way there. I would just add the extra 1:2 transformer and do it right.
I think another balanced input post EQ is a nice bonus. I think it is worth the extra expenditure to make it stock.
2. If you decide you don't want to spend for the extra 8 transformers you can just put in two normaling 1/4" jacks at the insert point to be used at the risk of the operator. This would just be a convenience I/O that would be better than nothing.
3. Skip the insert all together because most people will probably be fine putting outboard gear between the DAW/converters and the channel strip anyhow.
ruffrecords said:I would enjoy designing the PCB far more. So you might as well make provisions for the alternatives while you are at it.
bluebird said:I shouldn't forget you are a seasoned designer so you know what it would take to make the extra pcb, and if its not that big a deal for you, I think it is a great idea to give the buyer a choice, or to make future upgrades.
ruffrecords said:Which begs a question which PCB mount XLRs to use. I don't like the plastic ones at all. Can you get male/female right angle PCB mounting metal XLRs??
