Greg
[quote author="gyraf"]In the channel, C12 - the 330uF blocking DC from the gain pot - seems to be very small. at max. gain is's looking into 22R, so you'll loose low-end at high gain. Normally you see 2200-4700uF here. And it should preferably be very good quality, possibly shunted with a small polyester cap.[/quote]
What's considered a small cap... 100n? 100p?
[quote author="gyraf"]I don't really like that they use the mic preamp for tape return - first attenuating with R10-11-15, and then gaining up again. Couldn't this be taken directly to the insert switch in stead?[/quote]
I was also very suprised by this. My last board, which was a piece of crap, didn't use the mic preamp. I was under the impression that most boards were designed as my last one was. Let me ask you a question about this circuit. It looks like there's discrete differential front end that is debalancing the signal, then the 1st half of IC1 is a just a fixed gain stage, correct? If I were bypass this gain stage, could I still use the debalancing circuitry or would I need an additional circuit (or tranny) to do the job?
[quote author="gyraf"]Loose C4-5-6-7, the electrolytics in line/tape inputs. I'll bet thet your source outputs already has these.
C18 (at HPF OFF) could be substituted for a 470nF polyester.[/quote]
Thanks and thanks.
[quote author="gyraf"]Bypass C44 with a small polyester cap. This drives all output from the channel.[/quote]
When you say bypass, do you mean shunt it or replace it. I'm not exactly sure what you mean. Small - 100n? 100p?
Thanks for all the advise Gyraf it's definitely appreciated.
Thanks and thanks.
