Rob Flinn
Since you seem to have faults in every part of this console if I were you I would try to approach this a bit more logically than just swapping stuff out.
Personally I would do something like this
1. check the Power Supply
2. remove all channel modules & get the master section going. If you have an option for a stereo return use that to put a signal of some decription into the master section & until you have that working don't worry about the channels. Replacing the feed resistors because they're near a burnt section is a bit of awaste of time in my view.
3. Look at the channels one by one.
In my experience when a console has been stored like you say yours has then it is worth while looking at the caps first. There is no need to up the voltage rating. Some people replace double the capacitance of the the audio path caps, which halves the low frequency cut off point for that point in the circuit. Power supply decoupling caps are normally kept the same value because making them a lot bigger potentially can blow your PSU with the increased inrush current at switch on. It is worthwhile getting 105deg caps. People talk about certain caps sounding better than others, but the reality is if the caps are shot in your console anything is going to sound better than what was in there.
Quite often if you recap the next area to look at is mechanical, i.e switches & connectors. I restored a desk that was in quite poor condition & there were no blown transistors or op amps apart from on some VCA boards. Once I had worked out the symptoms compared to which op amp on the VCA board was blown it was quite simple to get all the VCA boards going. I didn't need to replace any resistors.
It is quite useful to have some sort of scope, it doesn't need to be fancy just something to trace a sine wave. Using a scope & a sine wave from Pro Tools (other DAWs are available) it is easy to find the area of the fault.
As people have suggested randomly changing components for no reason at this point is probably not the way to go.
