Allen & Heath System 8 Mk1/2 recap and mods
Thank you very much, Neil - it is beginning to make sense to me.
You mentioned that C8 and C9 are in series with a 22k resistor, but as far as I can see, they go directly to the next TL072?
C1 on the output cards also go directly to the op-amp - how would you estimate -3db point in that case?
Thanks for clearing that up
I mentioned Z5U because I have a good source of these in axial form, that seemed practical. I’ll get X7R instead.
Is local power rail decoupling by the ICs generally advisable, or is it only necessary if I change to different op-amps?
Do you think I could improve anything by putting in new TL072’s, or would they perform exactly the same as the original ones from ca.1984?
Did you ever finish?
Write your reply...
