AUDIOPOTS
New member
- Joined
- Apr 28, 2012
- Messages
- 2
Hello guys, greetings! Frank Santa, I have an ADR unit F760x I just do a re-cap of all electrolyte, the unit works fine except channel 1 was not delivering the same levels as channel 2, I'm looking for information on performing internal alignment would need the manual and what is the procedure, I have: function generator, true rms AC millivoltmeter, Oscilloscope, etc, but I'm not familiar with this type of operations.
The ADR is factory with balanced inputs and outputs via ELMUS type transformers 82 and 83, I have understood that to apply a sinusoidal signal 1Kz for example, would have to bridge pins 1 and 3 of the input? and for the same output?, also I have doubts that any resistance would have to use the output shunt?.
Appreciate it if anyone has expereriencia in all this can help me, I'm truly at a crossroads.
thanks
Frank.
thanks
Frank.
