> feeding cathode
Actually: feeding 2K||2K to ground.
The cathode hangs-on near there, but its loading is reduced by high NFB.
The network is, by inspection, classic RIAA. The midband gain (~~1KHz) is about 99.8K/1K or 100, a typical 1KHz phono gain. The highs roll-off to unity, and will be around 10 at 20KHz. The lows rise toward 1.56Meg/1K or 1,560. Which is higher than the RIAA 20dB rise over 1KHz, but the forward gain of two degenerated 12AX7 stages is not a lot over 1,000, so we have to trim the <50Hz gain to hit RIAA.
V1B wants a grid resistor.
