adrianh said:For all you lurkers
You are missing a great circuit.
Can I say a 7 transistor mic pre (discrete that is).
And this thing will smoke all the commercial junk made today.
And no it will NOT sound like a plug-in.
clintrubber said:Is the top of R30 (= 'G') simply connected to '0V' perhaps ?
clintrubber said:So let's have a look at that mentioned Designs Department Handbook No.3.194(77)
Roddy, do you have access to that by chance ?
rodabod said:clintrubber said:So let's have a look at that mentioned Designs Department Handbook No.3.194(77)
Let me have a look tomorrow. Several mic preamp designs were made. Some fancier than others.
What makes all of the BBC gear very good is, very high build-quality, great documentation with labelled test points on the PCBs, and gear that was designed by ear as well as pencil. The vast majority of transformers used are Sowter by the way.
clintrubber said:(I bet somebody is already working on a dual-pre in lunchbox format )
rodabod said:Just looking through the docs. I have at home, there is also a twp-stage mic amplifier named the AM9/10.
I'll try and source that tech. doc you were looking for when I'm back in work.
These are busy & uncertain times. Big institutions should reduce clutter & hassle by getting rid of irrelevant inventory !Maybe I should ask about taking home the never used audio eq. lunchbox they have there too...
Are you working on an original format PCB (like in Peter P's picture on page 1 or lunchbox or other?hobiesound said:if all goes well i'll be posting a pcb for this pre.
mitsos said:Are you working on an original format PCB (like in Peter P's picture on page 1 or lunchbox or other?hobiesound said:if all goes well i'll be posting a pcb for this pre.
mitsos said:Also, is there any sense in doing a Sowter group buy for the trafos?
peterc said:Hi all
What happens to the connection marked PLA13 (bottom right)?
