peterc
Thx Pete, seemed to have missed that......
hobiesound said:ok here goes, these are the UNVERIFIED schematics and layout for the AM9 minus 15k filter and mute circuit.
I decided to go for a separate gain pcb so i can use a standard MBB lorlin pcb type switch coz i'm cheap!
i changed the output transistor and it's associated current source transistor to bd141
tv said:Are you sure about Q4 (BC141-10)?
It looks to me like it should be a NPN ccs (a very "cost-effective one") ...
clintrubber said:hobiesound said:ok here goes, these are the UNVERIFIED schematics and layout for the AM9 minus 15k filter and mute circuit.
Hi Thomas,
Nice action !
You mean BC-types like in your schematic, right ?
Bye,
Peter
Davo said:Very cool! Thanks for sharing!!! ;D
Just wondering a couple things.... what kind of inductors are you using? Not really sure how important they are.
Davo said:And the "gainboost"... it looks like your connecting an spst between R21 and ground, am I correct here?
Davo said:So a modern equivalent usually being around 10k for line impedance, what would be suitable alternatives?
600:10k (1:4) for the input.... seems reasonable... the Lundahl LL1530 is actually a 800:10K 1:3.5
2.5k:10k (1:2) for output..... seems reasonable as well, these are a little bit harder to come by, the Lundahl LL1544A will accomplish
this.... is it important to maintain the output tx's primary at around the 3k?
clintrubber said:For the cheapo's or at least for a first version of this pre, how about the OEP models ?
Or would that clash with the 'direction' of this pre ?
rodabod said:clintrubber said:For the cheapo's or at least for a first version of this pre, how about the OEP models ?
I'm sure you could try anything, but that certainly isn't what the original designers would have fitted. If someone wants a dirty/coloured preamp, then I'm sure the FETboy would probably be a good choice.
Also, the 1:2 OEP won't probably function very well as an output transformer here.
clintrubber said:I understand what you mean, thanks for in fact confirming to avoid the OEP-route!
I'll never forget those gloomy showers @ YMCA Chicagorodabod said:clintrubber said:I understand what you mean, thanks for in fact confirming to avoid the OEP-route!
Never say never!
Unless a strange man asks you to pick up a bar of soap in the men's showers.
