Ampex MM1100 Variable Speed
dawsonaudio
Long Beach, CA
I've been investigating hooking up a variable speed function to my Ampex MM1100/16 track.
Mainly, I'd like to throttle the speed down a little lower than 15ips. 7ips had a little too much high frequency roll off so I'm looking for something in between.
Would it be possible to send a signal from one of my DAW ouputs into the Ampex Variable Speed plug on the back of my machine. It looks like there is a dummy plug connected. 9600 hz is the frequency that the deck is currently using. I read in the Ampex manual that connecting to pin 2 (hot) and pin 3 (common) of the Variable Speed socket, I could add vso.
I'd create a track in my daw, insert a signal generator and feed that to the ampex deck. I'd wire pin 2 and pin 3 of the xlr out from my daw accordingly and float the ground lug at the input of the deck/variable speed socket. Would this work?
Thanks for any advice here.
Nate
I was able to get a good signal into the tape machine varispeed ref/in and adjust the tape speed via the DAW frequency generator, but the tape machine has a little flutter/ wobble to it like the tone generator isn't as precise and clean as the onboard reference 9600hz.
Any recommendations for a sub $200 dollar stand alone function generator that would work better than the output of my DAW?
Nate
I've been wanting to try out the 'in-between' speeds for a while now to see what the tape machine would sound like at say 22 1/2 IPS or at some arbitrary number like 12 IPS.
I don't have noise reduction for my deck so part of the reason I'd like to try speeds higher than 15 IPS would be to see if I can get a little less tape noise without going to 30 IPS which I don't really care for with the music I'm recording. Of course I can adjust eq to tape, but wanted to give the speed variation a try.
