clintrubber
[quote author="PRR"]But with all the other suspected transcription flaws, and the fact that this company's products are more than the sum of the parts, so they hate to see schematics in public, I'd rather drop it. If you want to copy another Man's product, you need more than the schematic, you need the parts-selection, the build-quality, the critical inspection, and the karma (I believe there is good karma on that Man's assembly line).[/quote]
Agreed, looks like there are too many things not surely known for that circuit. Original idea was to have an active stage and since that one was designed for driving EQ-sections as well it seemed right for the task and a good kickstart. Cloning that to get a bit of M' aboard wasn't the intention and would have been naive. Having observed those several odd things though, the curiousity kicked in :wink:
that one does have those caps indeed connected to the 5532
( http://sound.westhost.com/p24_fig1.gif ), but here they're connected to the final output.
A simulation says the load of the 5532 is over 2k5, but I guess that'll vary with circuit-params. It looks however well enough above 600 Ohms.
I recall a short article about simply redimensioning the circuit to solve the incorrectness, but I see nobody doing it.
And I could keep overdoing things by adding an offset-adjust to the OP07).... sigh, like you already mentioned just stacking those 5532 and a few resistors wasn't such a bad idea :wink:
Peter
As drawn here it's unlike the ESP-design:> it'll just work, no mysteries.
Well, it will work, but there are issues.
At a glance: the 5532 is asked to drive R1||R2 through C2 C7 and the AC-grounded supply rails. 235Ω, woof. If the 5532 could drive that, two in parallel could do the 100Ω simpler than all that other stuff. (In fact it would take 6 to 10 sections of 5532 to drive 100Ω well.)
I started from Jakobs headphone-driver topology but I've been wondering indeed when one chooses to drive from the top and when entering the diode-stack midway.In fact it is not necessary to bootstrap to both supply rails. Let the opamp drive the top base, and use diodes and resistor/bootstrap/CCS the bottom base.
You're right, biasing should increased for A (FWIW, but let's say we want that).Idle current of 40mA is not bad, but is neither Class A nor Class B for large swing into 100Ω. It is class A up to 8V peak.
You're right, all those circuits out there using this aren't exactly correct. I've been thinking of doing it 'more correct' but IIRIC this way of doing it isn't that bad since source impedances will be low. Ad when using it as an insert I'll be running unbalanced anyway, so less circuitry would be better then.The input impedance of these one-opamp "balanced" inputs is never balanced, though it never seems to matter in studio work.
Thanks, I'll try to get hold of specs for the coils (likely Toko's). That OP07C opamp in the DC-servo has an insane offset-spec, I want to use it just because I have a few available. So the output will be low in offset (will check/think whether the offset-spec of that opamp guarantees that the complete circuit will be low in offset, but I guess so: input-current is low as well so as long as R8 & R15 are well matched all should be fine.> VDC as presented to the EQ below say 2mV.
Find out how much DC your inductors can stand, and their DCR, and how much of the amp offset voltage reaches them.
But I'm not sure how to scale this to treble coils, you better check the actual parts.
Peter
