KrIVIUM2323 said:
Congratulations Metoo2!
Which kind of transfo did you use finally? 10k/600 or 10K/150?
And B+ for 6k4P? 240V as specified by Rotheu with 6BA6?
Rotheu's original design is stable and I'm sure it works. I am currently looking at using Edcor XSM50K/600 and XSM600/50K transformers in the signal amp. I ordered them as a special from Edcor. Because I paid for the one off design charge other people should be able to buy it for the "normal" price. I also intend to test the XSM10K/600 and XSM600/10K in the signal amp and possibly other combinations if I have time. Control amp uses XSM10K/600 and XSM600/10K. B+ on the 6k4P currently set to 150V. That gives loads of headroom so far and I haven't got it to clip yet. I might back it off a bit to say 125V. Could be out of contact for a while though as I have some new work that is taking away my play time.
[edit] OK it was a rainy Saturday & Sunday here, so I built the second signal amp channel with XSM600/10K (in) and XSM10K/600 (out). The first channel was XSM600/50K (in) & XSM50K/600 (out)
Also looked at the combination XSM600/50K (in) and XSM10K/600 (out) and XSM10K/600 (in) with XSM600/50K (out).
I think I'm done tweaking for now.
I've come to the conclusion that the 50K output transformer does indeed make a difference on the output (at least on my build.)
I've also come to the perhaps surprising conclusion that it's going to be better to reduce gain in the compressor rather than add it. That means a 600/10K input transformer. My reasoning is that if I want to use this on the mix bus or on pre-tracked signals then I don't need 12dB of gain and it is better to allow a higher input signal in for the same output so that relatively speaking the noise floor drops. That means the upstream component would have to provide more gain so it's maybe just shifting a problem around. Anyway, there's nothing for free in valve circuits so you may come to a different compromise for your build. The alternative transformers only cost around $13 so you can play with these combinations yourself without breaking the bank.
So to summarise the tweaks I've made to Rotheu's design for my build (and ALL due credit to Rotheu of course, because I tried a lot of tweaks and many of my bright ideas actually made things much worse compared to his design)
1) built a dual mono version with original 660 timing chain - changed capacitor values to modern equivalents e.g. 4uF ->3.9uF 20uF ->22uF 2uF -> 2*1uF
2) Used 8 * 6k4p-ev tubes per channel. Important to get the higher quality EV (or EB in Cyrillic) version.
I manually matched these on a simple test set up (bought 30 and got 2 channels of 4 pairs of 2 tubes = 16 tubes in use in signal amp)
pin 1 is grid 1
pin 2 is grid 3 (suppressor + shield) which I hard wired to pin 7
(on my 6k4p-ev tubes this is actually hard wired internally within the tube but I don't think that's the case on the 6ba6 for example)
pin 3 & 4 are the heaters.
I used 6.3V AC heaters with 2 * 180 ohm to ground to simulate a centre tap. You could of course use DC heaters if you can build a 4.8 amp supply
pin 5 is anode (via output transformer to 125V)
pin 6 is screen grid.
Connected to pin 5 via 10K screen grid stopper PER tube soldered directly on the socket.
It worked for me. You might want to tweak this.
pin 7 is cathode
3) B+ on the 6k4P set to 125V. B+ on ECC99 300V. B+ on 12ax7 & a12au7 245V
Quiescent cathode voltages: ECC99 around 10-11V. Similar for 6k4p around 9-10V.
The signal amp balanced well with the pot in the middle and without any tweaking (guess the tubes were well matched as I selected them as 4 matched pairs per channel)
4) Changed signal amp transformers to XSM600/10K & XMS50K/600. Due to this choice, the gain drops right down to around 7dB but I believe that the effective signal to noise ratio improves because you can drive the input harder (which I thought to be more inportant). So maybe more like a 670 than a 660.
5) Changed cathode resistor for ECC99 to 470 ohm. You could probably get away with lower but I didn't see any benefit
6) wired anode of 12au7 and 12ax7 to regulated 245V rather than to the ECC99 via a dropper resistor
7) wired up the output transformer so that the whole things was non-inverting
8 ) wired ECC99 unregulated to 300V (stabilized via 12H choke).
9 ) I still have to wire up the VU meters but I'm going to have them switched so that you can also measure the output signal as well as the gain reduction. See no point in measuring the balance myself. I find it easier to do that with an external voltmeter or a scope.
10) for the power supply I used two transformers & two supplies.
Transformers were the T30 model from analoguemetric, connected to an off the shelf Variable HV BJT Power Supply also from analoguemetric containing 2* 100uF 450V aerovox capacitors, plus two 12H Hammond chokes (193b) on each HT power supply. The variable supply also provided 2*12.6V for the heaters for the control amp..
So in total:
2* 2 * 6.3V AC @ 1.2A to power 4 6k4p each winding = 4.8A total for 2 transformers
1* 220V ac 100mA (for 300V on the ECC99 via the choke and regulated to 245V for control amp of a few mA)
1 * 200V ac 100mA (regulated to 125V DC on the 6k4p of the signal amps)
I should also mention that Tube-Town in Germany and Edcor (USA) also gave me great customer service on this project.
Is it a real 660 or 670?
No of course it isn't. But it does seem to act something like a variable mu compressor should and with vaguely similar specs
