Sorry, people, I f***ed up! I feel very bad now! :-[
My apologies for this. I want to thank Hop.sing for noticing my mistake. It's crazy how obvious the mistake is when I look at it now, after he mentioned this. It's so in your face!
Matthew, I'm very sorry for causing you this problem, since you started building the switch! :-[
I just want to mention that I never claimed that I build the actual switch, you can look through the posts. I built the prototype signal and side chain amps and I tried all timing settings by soldering the resistors and caps and bypassing the original 660 timing network and they all worked great. I was planning to make a double sided PCB for this switch and use two PCB mount 2 pole 6 terminal Alpha switches. Normally, a switch is not something you make a prototype off, but I guess in this case I should off done that. I came up with this switch after I built the prototype compressor.
Also I never stated that this configuration sounds better than series resistance. This is the quote from my post:
I think having resistance in series with CV (attack potentiometer) will change the character of the compression and the way it behaves. There got to be a reason it was designed this way, using different capacitance values to change the A/R times.
Regarding efficiency, yes I agree that series resistance is more economically efficient than this configuration, but not electronically. After building 10W or 5W power amp, I don't think it's efficient to waste all that power as heat in the resistor.
There is one obvious solution for this. It is to use 6 deck 6 terminal switch for release. That will isolate the resistor butches for each cap. But unfortunately it's not a poor man's solution. That switch will cost a lot. At this moment I don't see any other way to do it, but I will think about it more and hopefully come up with something. This time I will definitely build it before I post anything!
I want to apologize again for all confusion and trouble I caused! :-[
