Matthew Jacobs said:
lolo-m said:
Have fun and stop before the headache becomes too hard
LOL....
I think I will stop before I begin... ;D
6 to the power of 6 signal paths through resistors, that means 46,656 calculations
yeah, I now realize how crazy this labyrinth of resistors is.... Some in parallel, some in series... Must be possible to sort out with a computer, but there must be a easier way.... surely there must.....
For example:
1 attack switch and 6 release switches....
Imagine the front panel design.... lolo-m you might like that.... will look good next to your crazy looking GSSL (IIRC). I saw your build photos on the french forum...
Or maybe a release switch made up of a gang of 6 stacks...
Or just stick to the original time network...
J
I am in the same position as you are. What to do? I was just about to solder the crazy thing, when I saw the problem. Now I want a little bit flexibility, a long attack with a variable release and so on.
My Vari Mu has turned out to be like a little child in the meantime, it grows and grows, makes a lot of work, but is real joy, too.
I started with the prr design and pcc189 tubes, tried out all kinds of make up amps and so on.
Than I found the E.A.R schematics on the net and cloned the very clever solid state sidechain circuit and the biasing circuit, which is basically a fairchild 660 biasing circuit (Not 670, I learned that in this great thread, thanks), paralled two pcc189 per channel into a lundahl LL1660 in 4.5:1 configuration and now I need a timing circuit, that fits my needs.
By the way, what I found out is, that the biasing method with the negative voltage on the balance pot is a huge contributor to the sound of the compression.
With the easy biasing method (Cathode just to ground with resistor and balance pot), you need much less negative control voltage for the same amount of compression, than with the fairchild way. I do not really understand that yet, but I have -12V on the grid where I had -4V before for the same amount of gain reduction and compression sounds definitly different now.
I did not measure the voltages on the cathode during compression, but probably they are moving in the direction of the grid voltages with the current changes (because of the negative supply voltage on the balance pot) so the grid has to go a little further.
Back to the timing network. for now I use a 4,7 uF cap with a 5K attack pot and 100K release pot and it sounds good, maybe I leave it that way. No resistance in front of the cap might sound a little different or better, but I have no idea how to implement that with some kind of flexibility.
