Larrchild said:
Nice work Rotheu!
You have all the good parts of a Fairchild built.
6BC8's have a "speedbump" in the transfer function at about -12v that 6BA6's, which look like a near-straight line out to 80v, do not, but your sidechain needs are smaller.
If you move to 6BA6's, you'll have to increase sidechain torque, but otherwise, enjoy!
Bravo.
Add some negative feedback to the sidechain 2nd 12AX7 cathodes. It'll get even faster.
BTW, did you ever try a 12AU7 there? Might be a better fit.
Hi, Larrchild, thank you very much!
I think I'm gonna stick with 6BC8's. I like what they do.
I can easily slam it by 20dB of GR, that's more than I will ever need.
Also, like you said, the sidechain needs are much smaller, which makes it possible to use cheap
transformers and have maybe not exactly the same but very similar results.
6BC8's sound very different in Fairchild type compressor, compared to something like UA175,
which makes me think that in case of compressors the sound is not that much
in the tubes and transformers, but mostly in topology and RC network. I might be wrong though...
That's interesting that you advised me to add some feedback to the 2nd 12AX7, because I actually
reduced it, probably thinking in terms of voltage gain. Now when I think about it... Is it the
output impedance, which will be lower with more negative feedback, meaning the sidechain will
have more current drive?
I will try 12AU7 instead of 2nd 12AX7. Do you think that will require some component
changes?
Analag advised me to change the output tubes (12BH7). I'm thinking of ECC99 , but my concern is
the output transformer rated at 2.5W RMS. ECC99 can have 5W output. Do you think it's a problem
in case of sidechain to overdrive the transformer by that much? What tube would you recommend?
What do you think about my idea for the timing network? It's a big load on the
sidechain, especially with long attack and short release settings, but so far everything
worked nice. Love those long attack/short release things...
Again, thanks a lot, Larrchild!
