emrr said:I recall rising 6db/octave for power rating. So +35 dBm max at 20 Hz will do +41 dBm at 40 Hz. etc etc.
emrr said:Sounds basically correct. I gotta think we don't have frequencies below 40Hz very much, at least not of any significant level. Kick drums and pipe organs. Anything down there will saturate and distort, and that signature will get into the compression CV. So, reduced compression at those freq because of inability to pass accurate signal. Creation of lots of third harmonics related to those signals, effecting compression. Steady state overload may cook transformer. Pipe organ? Doubt a kick drum could ever do it. What wattage down there can the amp stage actually deliver to the output transformer in the first place? Is it even an issue in current design?
nielsk said:SC filter?
We have to think that the push pull amp isn't a real push pull... I mean the sc amp is two amplifiers amplifying one half of the signal. If the output power of the amp is 5W in a real push-pull it will be only 2,5W in a Fairchild SC amp...emrr said:Steady state overload may cook transformer. Pipe organ? Doubt a kick drum could ever do it. What wattage down there can the amp stage actually deliver to the output transformer in the first place? Is it even an issue in current design?
lolo-m said:We have to think that the push pull amp isn't a real push pull... I mean the sc amp is two amplifiers amplifying one half of the signal. If the output power of the amp is 5W in a real push-pull it will be only 2,5W in a Fairchild SC amp...emrr said:Steady state overload may cook transformer. Pipe organ? Doubt a kick drum could ever do it. What wattage down there can the amp stage actually deliver to the output transformer in the first place? Is it even an issue in current design?
We have to think too that the SC-amp output is fonction of the compressed signal. Only peak will deliver full power in the SC-amp, then the signal will be compressed an the SC-amp will only deliver a fraction of it's power capacity... A Fairchild comp is a looped amplifier...
Maybe this helps, maybe not !!!
Larrchild said:Hey rotheu,
The NFB just lowers the output z, albeit at the expense of some gain, yes.
Lower output z charges things up faster.
The 12AX7 following another just seems like overload potential with it's sharp cutoff.
12AU7 plate lines look more like a 12BH7.
analag said:Larrchild said:Hey rotheu,
I don't believe he heard you...that's one of the things that popped out at me. 12ax7 driving 12ax7, hmmm.
rotheu said:Timing network with independent attack and release controls and true stereo linking (two linked networks are isolated and don't affect each other)
veermaster said:rotheu said:Timing network with independent attack and release controls and true stereo linking (two linked networks are isolated and don't affect each other)
Sorry people, I gotta ask:
Does this network also work in Analags version of the PM660?
I really would like to add an independant attack and release switch.
Thanks in advance!
emre
nielsk said:are the big caps in the timing network non polar?
Sorry to answer so late but this Rotheu's time network doesn't work with the PM660 without any mod. If you do my last mod (SCAmp buffer), it will give something close. Don't forget that the GROUND in Rotheu's TC will become the adjustable -4,5V in the PM660...veermaster said:Sorry people, I gotta ask:
Thanks in advance!
emre
