nielsk
Did you happen to try this with the 175 output section only? (no extra 12AX7 / DC Threshold stage)
nielsk said:Did you happen to try this with the 175 output section only? (no extra 12AX7 / DC Threshold stage)
Hi, Jean-ChristopheTHE BAD DOGS said:Hello,
VERY NICE PROJECT!
I want to do this project and have some questions :
* Is there a bom list?
* On your pictures it seems to be a parrallel circuits with 4 tubes on each, one with 6bc8 and other with 6ba6 and a knob to switch between? Do you think you use this solution at least or you only stay with 6bc8 design?
* In case of building a "monster" with 2 parrallel circuit with each kind of tube, is there anything to change in the schematics after (you were talking about 6v6 output)?
* What about the "sum and lateral" linking mod instead of stereo linking mod?
Best regards,
Jean-Christophe
veermaster said:Rotheu, what is the 1Meg Resistor+Diode+10nf Cap in your Timing Network for, is it really needed?
Thanks, Emre
SUPERMAGOO said:nice project!
pcc189 have tried to use instead of 6bc8?. some time ago I adapted the circuit Altec-436 to be used with pcc189
with good results.
djn111 said:Hi,
I like to have a go at this, but some specific questions:
- the input pot. lin or log
- the meter a real VU or mA
- the 200 balance pot is to balance the u variantion in the both up en down tubes right, so a zero volt DC offset.
- how to calibrate
- how did you organise the power supply recetifier tube/solid state, CLC,300V,RC, 240V, if so can you help me with the current of the first to supply voltage, and how did you reg the 100v, current is changing with the settings, I was thinking 0C3 but the current with a grid off 0V, Ua 100V means 4x 0.36mA = 144mA way to much for a 0C3.
Dirk Jan
syn said:Rotheu
thank you very much, for this excellent project. How about W rating of the resistors and V rating of the caps?
Thank you once again.
Best
Good point!lewilson said:I just finished fairchild 660 clone. I used the Russian version of the 6ba6 tube, the 6K4P. It is a very nice tube.
I bought 30 pcs, but the first eight I put in were a good match. At this point its easy to buy a bunch that were from the same batch and so there specs are very close. Plus they are cheaper than a used american made 6ba6. Just a thought.
